Use this procedure to configure an NTP address for the DHCP Server to advertise to
clients.
- Select DHCP Server.
- Select the Global NTP tab.
- Select Insert.
- In IP Address, type the IPv4 address of the NTP server.
- Select Insert.
Global NTP Field Descriptions
Use the data in the following table to use the Global NTP tab.
Name | Description |
IP Address |
Specifies the IPv4 address of the NTP server. You can enter a maximum of eight DNS servers. |
Origin |
Specifies the origin of DHCP Server configuration, either manually configured through CLI or EDM, or dynamically configured through RADIUS. |
